O.F.M.,
Assuming your radiator is "book" mounted, go through the nose/scoop first. 1/2" or 7/16's socket and a short exstension should get you to the bolts holding on the upper radiator brackets. Remove the one bolt on each bracket and remove the brackets. Then go under the nose and lift the radiator up to clear the lower brackets and slide out from under neath- ten minutes......after you drain the radiator. Shouldn't have to mess with the hood or the hood hinge?
DV
