03-03-2009, 07:37 AM
Cobra Make, Engine: SPF#0760
Ya know, adding a ground to the gas cap is an interesting thought. The cap is bolted to fiberglass and isolated by a rubber connecting hose on the tube, at least mine is. I guess you could look at it two ways. The cap is isolated and should not be a problem or its grounded and should not be a problem...Think I'll run a test to see if it's grounded with an OHM meter tonight....Anyone who also has a vette in the garage could also check it to see if it's grounded. GM surely would have thought this issue out....
SPFWiringDiagrams@Comcast.net
