Old 03-03-2009, 01:44 PM
Ron61's Avatar
Ron61 Ron61 is offline
Just one question if you don't mind. After reading the bill with all the changes I am still not sure if this will only apply for the year of the Amnesty Program or if it will basically do away with the 500 number limit and keep the same standards to be tested as SB-100 has. I may be wrong on the Amnesty Program just lasting one year, but what I would like clarified is will this bill basically replace SB-100 without the 500 per year limit? It keeps referring to Section 44017.4 of the Health and Safety Code which I will paste below which gives the owner the right to choose if body style or engine year is to be used. Yet is has been my understanding that California did away with the year of the block some time back.
44017.4. (a) Upon registration with the Department of Motor Vehicles, a passenger vehicle or pickup truck that is a specially constructed vehicle, as defined in Section 580 of the Vehicle Code, shall be inspected by stations authorized to perform referee functions. This inspection shall be for the purposes of determining the engine model-year used in the vehicle or the vehicle model-year, and the emission control system application. The owner shall have the option to choose whether the inspection is based on the engine model-year used in the vehicle or the vehicle model-year.
(1) In determining the engine model-year, the referee shall compare the engine to engines of the era that the engine most closely resembles. The referee shall assign the 1960 model-year to the engine in any specially constructed vehicle that does not sufficiently resemble a previously manufactured engine. The referee shall require only those emission control systems that are applicable to the established engine model-year and that the engine reasonably accommodates in its present form.
(2) In determining the vehicle model-year, the referee shall compare the vehicle to vehicles of the era that the vehicle most closely resembles. The referee shall assign the 1960 model-year to any specially constructed vehicle that does not sufficiently resemble a previously manufactured vehicle. The referee shall require only those emission control systems that are applicable to the established model-year and that the vehicle reasonably accommodates in its present form.
(b) Upon the completion of the inspection, the referee shall affix a tamper-resistant label to the vehicle and issue a certificate that establishes the engine model-year or the vehicle model-year, and the emission control system application.
(c) The Department of Motor Vehicles shall annually provide a registration to no more than the first 500 vehicles that meet the criteria described in subdivision (a) that are presented to that department for registration pursuant to this section. The 500-vehicle annual limitation does not apply to the renewal of registration of a vehicle registered pursuant to this section.
(Amended Sec. 1, Ch. 693, Stats. 2002. Effective January 1, 2003
Thanks,
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
