Thread: Muncie Gear Box
Old 11-06-2001, 03:45 AM
Dominik's Avatar
Dominik Dominik is offline
Mike,
I thought the input shaft with 26-spline just calls for a 26-spline clutch blade and there you go.
Bellhousing and pressure plate are the same. Maybe not for the later LS-1 engines ...
Cal,
I used a M-20 behind my very torquey big-block for 7 years under hard driving conditons, not racing, and it held together perfectly.
The only modification was a sealed bearing at the input shaft.
I hated the ratio though. Gap from 3rd to 4th was too wide.
Dominik
If I don't respond anymore, that's because I can't log in
