If you do not like the way a car drives, regardless of how it looks you will not like it. I suggest you drive an ERA,Superformance,FF,Backdraft. Personel experience has proven the SPF (I have not driven an ERA) is a SOLID car. I have no fear of hitting bumps, railroad tracks. I see zero, nada panel rubs or rattles. I cannot say the same for the others. Make sure you get at least a 427 stroked small block or big block and 500hp or you will upgrade to it eventually.
Regardless if you buy a $100K Kirkham or a replica that is no longer in business rest assure you will be fixing it. There is alway something, visor comes loose, bushing need greased, idle needs adjusted, fan switch craps out.
