Just by looking at it totally electrical:
the resistance could be changed by using resistors in line or parallel.
i.e. two 100 Ohm resistors in para result in 50 Ohm total.
one 100 Ohm and a 50 Ohm in para result in 100+50 / 2 = 75 Ohm.
Two 100 Ohm in line - you guessed it: 200 Ohm total.
Matching it exactly through the hole range is a real challenge ...
Dominik
If I don't respond anymore, that's because I can't log in
