Thread: Stroking a 351w
Old 03-05-2009, 12:24 PM
Mark O'Neal Mark O'Neal is offline
Originally Posted by bmcnicho View Post
CHP sells a 6.125"rod length/22cc and a 6.200"/28.9cc rotating assembly. I was leaning toward the latter since it is a slightly higher rod ratio & lower compression ratio. The lower compression ratio should make it tolerant of pump gas. Do you have inputs between the two assemblies?
With that cylinder head I'd run the 22cc dish. With .010 deck and .041 gasket and the head at 61ccs that's only 10.25:1 compression.
You would lose enough horsepower dropping to 9.62:1 to notice and the 10.25 is livable with the aluminum head.
