Old 03-06-2009, 03:21 PM
cobrarkc's Avatar
cobrarkc cobrarkc is offline
Cobra Make, Engine: Contemporary 482 all aluminum Tunnelport Self built and owned since 1980 frame#0000017 and owner of frame CCX 33961 looking for an FIA body to go with it
Default Ignition Resistor
Does anyone know what you need the ignition resistor for in the Contemporary. I am putting in a MassFlo EFI system which uses the Ford EECIV ecu coil TFI distributor and I am converting to an alternator with a voltage regulator on it, also am using an MSD 6AL box. Can I just remove this and the wires to it?
Cobrarich
