|    Not Ranked
				 March pulleys don't line up
 Has anyone used a right side inlet water pump on your car ? My engine is ready  to set in and I used an Edelbrock #8843 LEFT hand inlet and I have a 3 bolt harmonic balancer and my March pulleys won't line up. I need a .350 3 bolt crank spacer or maybe an new pump altogether? . A early model water pump appears to be shorter and looks to line up. However the water inlet is on the Right side. I was going to  use coolflex hoses and maybe I can use the right side inlet ?...  . I have a  an early thee bolt damper. I might could change to a 3.4" damper length that has both 3 & 4 bolt pulley holes possibly ? If the early right side inlet will work , I will get a new water pump . I wanted the high-flow pump, which might have  not been needed anyway. The balancer I have now is a 3.050 length . I might  could get someone to make me a 3 bolt spacer . Thanks in advance for your advice too  .......Mike        ( 351W engine)
 My lower radiator outlet is on the driver side bottom.
