Mando, I agree with Fuzzy! Very nice!
My car is scratch built. I built a steel space frame, used C5 suspension, diff, ect. I converted the Diff to accept a driveshaft and bolted into the structual trans tunnel. I welded an aluminum cradle that attaches to the frame and supports the body. Since this picture I have put on a longer throttle cable which is hidden and moved the air cleaner out of sight and into a high pressure area. I molded the engine cover for the LS6 Vette motor.
John How much does you chassis weigh??? It looks very heavy Some Manufacturers go overboard with steel in a chassis resulting in a very heavy car
