Old 03-10-2009, 02:15 AM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
Default Hydraulic Internal Slave
I'm just fitting a hydraulic internal slave Its a McCleod unit. There's nothing in there to stop it turning apart from the hoses is this normal... The hoses are braided and I don't want them rubbing on the fork Hole of the Bell Housing ... Can someone Help!!!
Cheers Mark
