Old 03-10-2009, 05:11 AM
Karel289's Avatar
Karel289 Karel289 is offline
Cobra Make, Engine: DAX Cobra Chevy 305 TPI
Originally Posted by AC-460 View Post
Can someone tell me does the Mcleod internal slave just hang by the hoses or is there something that stops it turning....
Cheers Mark
Hi,
This is a long time ago.
But let try to explain.
The T/O bearing is located at the collar [box], and this one doesn't rotate.
The threaded part that take care of the position, has a "O" ring for fixing.
The T/O bearing main body, has a radial bolt and you get with the package a steel angle that should be fixed to one of the bearing collar bolt. [at the box]
So there is no rotation or sliding.
I am talking here about the first type of T/O bearing
Regards,
Karel289
http://www.donostia.demon.nl
My father told me when I was a child:
"Everything that needs to be re-done, the second time it will go faster"
