Old 03-10-2009, 08:47 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
You can measure across the seal hole top to bottom and side to side
Take the side to side as blue print specs( unless you have the specs)
Set up the main cap in a mill and with a boring tool set to bp specs, take a moon shaped cut which will move the hole back to a assembled round properly sized hole
