Old 03-10-2009, 08:57 AM
Got the Bug's Avatar
Got the Bug Got the Bug is offline
Originally Posted by ou812545 View Post
We recently installed my rebuilt 418 and the pressure stays at 43lbs at all times. We expect the high output oil pump to produce closer to 65lbs. My engine build suspect it's one of 2 things.
1. There is an air bubble in the oil pressure line.
2. The spring valve on the oil pump is set incorrectly.
In order to eliminate option 1, I need to crank the motor and bleed the oil pressure line at the gauge. Loosed the oil line with a rag ot remove the air.
That's what we are planning unless there is a better way.
Dan
It's possible that the gauge is bad. One option (before getting into the dash...which is a pain in the rear) might be to try and rig something up to check the pressure at the engine to validate the accuracy of the gauge.
Doug
