Thread: Steering Column
Old 03-11-2009, 09:31 AM
Double Venom's Avatar
Double Venom Double Venom is offline
JC,
Don't be a stranger........and welcome, you will find all the help you need here. Maybe not the part but you will get help.
The original donor columns were a tilt Chevette. However IDIDIT and especially FLAMING RIVER makes a column that goes right in. You can get them with a tilt and also a dimmer, or you can put a GM dimmer switch on the floor. FR also has the U-joints and shafts you need. Simply tell them it is for a CR Cobra and they should be able to lead the way from there.
Both columns are comparable but I think the FR is little cheaper too.
If your bored, jump over to "the other Ed's build with DV, (This forum) get a large cup of coffee and read on. The best manual "we" have at the time is there!
DV
