One small note on this
smallblockhead Going to 120 pound of torque and then tighting it to the next hole in the shaft sounds like about the 140 number. I did over torque the first rearend I did and cranked the spacer for the hub play. IMO you could also crush the hub bearing and cause bearing failure. Mine was a soft steel spacer. Not a machined steel washer. Rick Ps Doug is the man at ERA for all cobra repairs.
