Thread: cam advice
Old 03-12-2009, 02:40 PM
Three Peaks Three Peaks is offline
Rick is right, you need to match the components to have a truly drivable car that will have decent street manners.
Will you carb and intake flow enough for the cam and maintain vaccuum pressure? Will you heads flow enough to get the most out of the cam and intake? Will your exhaust choke off your gains or have you planned the proper exhaust for flow and/or sound?
Just stating the cam won't give us enough information to give meaningful recommendations without the other information.
Personally, I wouldn't use a 289 block bored .060 over. They are tough blocks, but that doesn't leave much sidewall to handle piston stress and heat transfer.
I will respectfully disagree with 767 above- nothing wrong with the KB Hyper pistons for your build. They are much more than just a cast piston and will work fine for your build.
Good luck with your build.
Bob
