Originally Posted by onefastmustang
I have an MSD 8478 on my motor. Does anyone know if it is Comp Cams Roller cam compatible or do I need to change the gear?
Thanks
Mike
I have the same distributor and just installed a new Comp Cams phenolic gear on it to go with my Comp Cams
steel core Hyd. Roller.
If the cam is
steel core you should use the Comp Cams Phenolic, If it's iron core use the Bronze.
Don
