Old 03-13-2009, 07:44 PM
byroncobra's Avatar
byroncobra byroncobra is offline
Default Thermo fans and gauge senders
Fellas
Any recommendations for 16" fan to suit my new radiator?
The prices vary from $250.00 from Harrison to $40.00 on ebay. Wondering if you get better cooling with curved or straight blades with some drawing more amps than others.
Does $120.00 sound about right for a thermo switch, relay, circuit breaker and wiring?
Also I'm sorting out temp and pressure senders supplied with my VDO gauges, the Ford engine loom already has connections on it that feeds back to main loom and computer. Does the computer need this info to function or can I pick up these wires and connect to the gauges? If not I guess I'll run separate wires from sender to gauge.
Thanks for any advice.
Greg
