Originally Posted by pcoghlan
My car did not come with a backup/reversing light. Does anyone know whether this is a legal requirement in the state of Florida?
Check the lamps and lenses and REJECT IF ...
d) The back-up lamps do not turn off automatically when vehicle goes forward, there is no indicator on dash that lights or there is no audible warning signal, if so equipped.
BUT, I would argue that an earlier provision was controlling...
Check the lamps and lenses and REJECT IF one or more of the following apply:
a) An exterior bulb or sealed beam,
if originally equipped or installed, fails to light properly.
Just go in, be very friendly, and act as if you're 100% sure of what you're doing and that back-up lights are not necessary on this car. Assure them that you are right and they are wrong. You'll proably win.
Source:
http://www.ppd.ufl.edu/pdf/Inspection_Manual.pdf
