T-56 magnum
Hi,
I just wanted to tell everyone that Tremec has a new 700 FT. LBS. T-56 MAGNUM. It is very much like the t-56 but has much wider drive & driven gears, multiple shifter locations, mechanical & electronic speeo drive and a 31 spline output shaft. These are all aftermarket transmissions and have Ford, GM, Mopar and AMC applications along with custom applications like V-12 BMW, etc.....
Forte's is one of 10 TREMEC ELITE dealers that will be selling the new T-56 MAGNUM.
I know the T-56 will fit into a FFR with IRS but it can fit with straight axle if the engine is moved forward a little.
Email mike@fortesparts.com for more info.
Thanks,
Mike Forte
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
