Old 03-15-2009, 01:56 AM
lal Naja's Avatar
lal Naja lal Naja is offline
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
I have a Butler, so my body may be a little different to yours, but with the same problem. The harness travels along the same area under the the door sill and up the back bulkhead. I cut a slot high in the bulkhead, directly into the trunk about 1" wide and 3/8" high. Then I flattened out the harness to make it into a ribbon wire so it's flat and is concealed under the bulkhead carpet. I would have preferred some great flat male-female bulkhead plug to do this with, but everything would be bulky and hard to hide. Chamfer the slot you make to prevent a sharp fiberglass edge from attacking the wire insulation. Easy way to make the ribbon is to spread out about 3 to 4 feet of some clear 2" wide box/packaging tape on a flat surface and tape the two ends to the flat surface (work bench). Then stick the wires to the tape to form a ribbon of wires. Then wrap the ribbon with the extra width of the tape. All the wires side by side are say 3/4" and tape is 2" wide, so fold remeining 5/8" of tape over each side. Then repeat the wrapping with another layer of box tape again by flipping over your ribbon. Makes a nice strong ribbon of wire. I did this ten years ago and it's still intact. Hope this makes sense. Arthur http://www.photoshow.com/watch/Aj2Jh9eZ
