Old 03-17-2009, 09:57 PM
ceslaw's Avatar
ceslaw ceslaw is offline
Nice discussion on adjusting the floats. That is exactly how I did it. Then put the plastic plugs in to make it easier to spot check it in the future.
But the point is well taken. Putting the screws back in is cheap insurance against a plastic failure.
Thanks for the good info.
Originally Posted by wtm442 View Post
They were brought to market so Holley could make more money. They are much more prone to leaks and resultant fires. Plus, the adjustment of the float level will NOT be as accurate as if you were using the brass screws.
Adjusting primary float level
http://clubcobra.com/forums/showpost...0&postcount=36
Adjusting secondary float level
http://clubcobra.com/forums/showpost...0&postcount=37
