Thread
That other guy named Ed and DVs CRII build
747
permalink
03-18-2009, 11:48 AM
Double Venom
Neutral
This is how I put in the external latches. Picture 1 shows the original shaft cut and a twist that puts the 'foot' where I want it when the hood is closed. If you don't put a twist in it (heat-vice grips and a vise) when the hood is closed the handle will never be pointed correctly!
Hope these help who ever is installing these type of latches. (The lower bracket is +/- 1/8th inch strap steel x 1" and bent into the large 'U', then is fiberglassed in place, when dried I drill one hole through the body on each end of the strap then I use 10-32 scres and nuts to also hold it in place.)
DV
12:25 PM
Double Venom
View Public Profile
Visit Double Venom's homepage!
Find all posts by Double Venom
