  #38 (permalink)
Old 03-18-2009, 08:45 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
OK, here is what I don't understand. Unless I am way off base, Shelby did not change the chassis layout and front suspension pickup points. They essentially changed the A arm to spindle mounting, and the spindle / hub / caliper assembly. Is this correct? If so, where do they get off saying they don't have the parts to help you? All they have to do is go to their assembly line, take two complete front suspension assemblies and ship them to you. They should bolt right on to your frame attach points, and they should have the same geometry as what you have now. It's more expensive than they would like, but too bad. It isn't that they don't have the parts to help you - they just don't have the parts to help you as cheaply as they would like to help you. Push them.
