I had to move the arm on the shaft as bob says, then Doug made up a clutch stop that I mounted to the footbox to stop the clutch from being depressed to far.
I have the clutch and brake pedals as far forward as they can go with the existing slots in the floor. I was told if I needed to move the pedals farther forward I would have to modify the floor a bit more.
There are movement restrictions as to how far you can push the clutch in, which is why Doug built the pedal stop. I believe he said it was 1.2" max. As for the brake, after moving the adjusters, there is a diagram in the manual with the correct distance for the bias bar.
m-a
live for the moment or it may pass you by
