Remember that if you lower the roll bar yourself, the rear brace is now at a different angle and likely won't fit into the rear mount anymore, and it will no longer line up correctly with the hole in the body where it enters. If you decide you want the roll bar to be lower, make sure you have the Kirkhams do it before delivery (if they even perform this service).
