Old 03-19-2009, 10:50 PM
Rick Parker's Avatar
No removable glass ones, but a few models of Holleys have a larger glass or plastic port, (about the size of a Nickel) allowing the fuel level to be viewed. The "Window" is built into the side of each of the float bowls and is not normally intended to be removed. On carbs without the sight plugs, the fuel level is correct when with the brass plugs are removed, the fuel just ever so slightly dribbles out, right at the bottom of the threads.
Rick
