Old 03-20-2009, 06:48 AM
john chesnut john chesnut is offline
Default Chesnut Xtreme Hot Rod Kit special!
If you are looking for something different that accelerates like a rocket, corners like a slot car, is easy to build, and turns heads like crazy, then you might want to consider my Hot Rod. At Run n Gun in 2007 it won the road racing (by 6 seconds per lap), drag racing, and auto cross, and it gets 30mpg too!
I provide a steel and aluminum space frame to which the C5 Corvette suspension cradles simply bolt into. The car has the stock C5 wheel base and track, so all of the Vettes good geometry is maintained. You get to use all the Vettes steering, sway bars, brakes, wheels, tires, transaxle and torque tube. I shorten the torque tub by 20 inches so that the engine is moved rearward for true mid engine balance. The finished car weighs 1840lbs! You can run any LS engine OR any small block Chevy engine.
With my kit you get:
- steel chassis with aluminum skins. Weighs 340lbs
- Fiberglass body, turtle deck, front snout
- Fiberglass dash
- Fiberglass seats with black vinyl upholstery
- Fiberglass engine cover (For LS engines)
- Black carpeting
- Aluminum windshield with windshield
- 12 gallon poly fuel tank
- Steering shafts with u joints, bearings, and support heims.
- Coil over brackets with QA1 aluminim coil over shocks w/springs
- Light kit
- headers
- Roll bar
- Aluminum wing
- Wilwood clutch and brake pedals with mastercylinders
- All brake plumbing, lines and fittings
- Simpson 5 point racing seat belts
- Chassis wiring harness
- Aluminum radiator with cooling fan
For a limited time this package is a available for $15,990. This include the shortening of the torque tube!
John chesnut jmcbigbelly@yahoo.com or 603-504-4106
The C5 parts can be purchased used from around $5000.
