Originally Posted by bobcowan
That's called a Push, or Tight. It's probably a fairly simple matter of suspension tuning. If you do a web search, you'll learn why that happens, and what to do about.
What Bob said is most likely your biggest problem. I did all of my suspension over and wound up with 12 way adjustable QA-1 shocks and spring packages and by the time I got through I could make my car turn with no tight or loose. Also tires as mentioned are a huge help. The reason I went the way I did was I had to change my settings for the different tracks and roads around here and the QA-1s were very easy to adjust the rebound on and when fitted with the proper spring rates they worked great.
