Old 03-22-2009, 09:10 AM
mikeforte mikeforte is offline
Hi romehe,
You can convert to hydraulic roller with little extra expense. If you need a parts quote I'll be glad to go over it with you. I have EVERYTHING needed in stock.
If you don't know what year you have I would disassemble to the block and access the condition of the inside like cylinder wall, piston & all and then go forward. If budget is what you need we can do that or I build 427-W that is always an option....
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
