Old 03-22-2009, 11:13 AM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by romehe View Post
thanks guys for all of the reply's
mikeforte im not sure what year it is i bought the car with the motor installed what numbers do i need to find that out ? i do not want to pull the motor at this time (i dont have the time) thanks again
The block casting number is on a pad above the starter. Sometimes it can be seen with the starter in place, and sometimes not. The block casting number will tell you what year it was produced.
As a side note, if you have a flat tappet cam, be sure and use oil with plenty of zinc, or use a zinc additive.
