Old 03-23-2009, 01:33 PM
tkb289's Avatar
tkb289 tkb289 is offline
Davide,
If the frame was designed around a 4 cyl motor, there could be a lot of modification needed to enable the use of a V8. There is also the rest of the running gear to consider as well ... transmission, differential and brakes.
If the car was designed around a V8 and set up for that, then it's a different story.
If you want a Cobra replica, then I would suggest looking into a well established brand, as can be found all over this web site.
If you want what appears to be a one of a kind hybrid looking sports car and you have the money and inspiration to put it together, then it could be a unique project.
One way to help make the decision is the following: Assuming the cost is the same ... imagine this car, all finished and running, sitting next to a well built Cobra replica all finished and running .... which one would you want to own and drive?
I know what I would choose, but that's no important ... it's what you want that matters.
Hope this helps.
- Tim
289 FIA --- ERA 2136
Build Log:
http://www.clubcobra.com/forums/era-...build-log.html
