  #153 (permalink)
Old 03-24-2009, 01:06 PM
shelby racer's Avatar
shelby racer shelby racer is offline
Cobra Make, Engine: Shelby CSX4788 with a Dawkins performance 490 ci iron genesis block hydrualic roller
Default Went by the technical advice of SAI
Originally Posted by rokndad View Post
I think that's what I was saying on the very first page of this thread. Take the calipers off and unbolt the rotor. The bearing slips off. My car is just fine, front end was easily aligned by a competent alignment shop that handles CSX 2000 and 3000 cars and no loose fasteners to be found.....and I've looked.
Again - per SAI when I talked with them and my mechanic talked with them - they gave us the protocol (including the need for a press) and told us it was a PITA. Then, the upright had to be re-machined because the bolts had come loose - discovered that ALL the bolts were loose on BOTH sides.
Why have you had to take your rotor off? How many miles do you have? You also stated on the first page that your rotor just slipped off like a typical car (probably like the many cars I have owned / worked on - including the 8 that I own right now) which is NOT the case with my cobra. You also stated that you thought that your spindle / hub assembly is different than mine. The 4700s that were built from the ground up in Las Vegas (I think between the time they shut down in South Africa and the time they started up at HST) were more like the original 4000 series - which came with a more original spindle / hub. Can you post a picture of what you have since I have posted several of what I have over the last 11 pages? As far as loose fasteners, there re loose ones all over my car - not just in the suspension.
Racing, bull fighting and mountain climbing are the only true sports, everything else is just a game. - Hemmingway
