Old 11-09-2001, 07:49 AM
Flyin_Freddie's Avatar
Flyin_Freddie Flyin_Freddie is offline
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
Thumbs up Jim brings up a good point...!
Jim's note is pretty much on target, Gary... I should have thought a little more about what you wrote, Gary...if the problem was U-joints, then it wouldn't go away when you up-shifted. The drive shaft maintains the same RPM at the same speed. Therefore, whether you're in 2nd or 3rd, if you're doing 65 MPH your driveshaft is doing so many revs independent of the transmission, flywheel, clutch, pressure plate, etc. There's a formula for calculating drive shaft revs based on your ring and pinion ratio, but I think you get the picture. Engine RPMs are independent of drive shaft RPMs due to different gear ratios, 1st thru 5th. If your vibrations go away when you shift up, then it's not U-joints or driveshaft related, I wouldn't think.
I'd agree with Jim's comments on possibly the clutch disc, pressure plate, or other rotating mass ahead of the drive shaft.
Thanks, Jim, for making us rethink this.
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
