Old 03-25-2009, 08:01 AM
Doug I's Avatar
Doug I Doug I is offline
Cobra Make, Engine: Waiting to Order a BDR, engine to be a SA C408. TKO to hook it up.
It's a little out of the box ...... but
Check a rodent hasn't chewed through some wiring causing you to now have a hot wire completing a circuit somewhere. If the block is part of the circuit you could be getting a reaction with the coolant. First thing I'd do is remove the battery and see if you still get pressure developing.
Pull a gear .... drop the hammer .... and enjoy the Drive !!
