Old 03-25-2009, 02:38 PM
tbracker's Avatar
tbracker tbracker is offline
Cobra Make, Engine: Everett-Morrison Gen IV, 427FE
Send a message via AIM to tbracker Send a message via MSN to tbracker Send a message via Yahoo to tbracker
Default Fuel filter location and air in the fuel.
I just read that one shouldn't locate a paper element filter on the suction side of a fuel pump as it could ingest paper particles and clog the pump. This just doesn't make sense to me.
I installed a 10 micron filter before my pump to protect it as well as the carb. A filter that creates contamination is an oxymoron.
Recently I've been having a problem with a leak somewhere in the fuel system. The engine will stall on acceleration after sitting at idle for a minute. I looked at the small glass filter I have just before the carb. and it was half full of air and the pressure was down around 3.5 psi. I tightened all the connections on the vacuum side of the pump. Pressure went back to 7.5 but after driving I had the same problem.
Could a filter on the suction side create vapor lock or am I just missing a small leak? I've put 6000 miles on this car before this problem emerged. Time to change the filter element? Could it be heat related?
