The first test I'd do is to test the fuel flow into the carburetor. Take the feed hose off and pump into a small container, running the engine for 10 seconds or so. There should be enough fuel in the fuel bowl to do this. With an electric pump, all you have to do is turn the key on. Ten seconds should get you about a quart. If the system is clogged, you'll notice a lot less.
