Brake Light Switch
I was hoping for some opinions on using a brake light switch that would be either the electric plunger type set up on the brake pedal, or a pressure switch set up in the brake line. I cant be bothered making a bracket for the brake pedal and I already have the in line sensor.
A couple of people have told me the in line sensor is painful and messy to change if it goes wrong, but I can install the sensor in line with the bottom of the main chassis rail so if it did leak any fluid couldnt affect any part of the car.
Regards.
Mando
