03-26-2009, 05:17 AM
NH
That's a good looking example you have. Doug has a few good pictures of his removable tranny cross member if you need some. Also if you need them I have the flanges here to make his cross member removeable before we discovered it already was. The clutch is a bit of a trick with such tight constraints within frame rails. Forte has a slick arrangement with a drilled and tapped block welded right on the side of the Quicktime bellhousing for a heim jointed CNC slave cylinder. Let us know if there are any questions or pics required.
