Hi Keith,
The Top loader has the same length and bellhousing bolt pattern as the TKO. I sell a FE input kit so you can use the same bellhousing and linkage with just a clutch disc change to 26-spline if you have a TKO-600. You would then just install a 31-spline yoke on the same driveshaft. The X-member mod would be the only change underneath. The speedo gear is different. Call me with any questions.
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
