Old 03-26-2009, 09:45 AM
elmariachi elmariachi is offline
Originally Posted by priobe View Post
elmariachi,I used a NPT aluminum plug in mine. If you put a tap in the hole and use an open ended wrench you should get the threads needed to install the plug.That how I did it on mine
Well, its already on the engine and to avoid getting filings in the oil, I'd have to pull the pan. It may be cheaper/easier (and certainly cooler) to buy a puke tank from Mickmate and just hook it up.
