Originally Posted by patrickt
But wouldn't a sacrificial zinc anode in a closed radiator system still create a gas?
I've had a
zinc anode in it since the beginning. I only started getting the pressurizing of the system when I added the UV dye.
I use 10% green anti-freeze and the UV dye is brown but turns green when put in the water.
The
zinc anode did not create any gasses before adding the UV Dye.
What is not normal about the 4 & 8 plugs?
Dan
