Old 03-27-2009, 09:07 PM
jimboryder jimboryder is offline
Cobra Make, Engine: West Coast, 460 bored out to 466, radical cams, aluminum heads.
Default West Coast Part No's
I have a build manual that came with my West Coast which is a 1991 build.
However, it does not give part numbers you are looking for. Through contacting Vern over the last five years and fixing issues I have learned some general facts. My rack and pinion are from a Mustang II, front brakes are from a 75 Nova, Rear from a SVL Mustang, Steering column (well at least the turn signal switch I had to replace) from a 79 TBird. Brake booster is Cardone # 5474000. Vern admitted he used parts from used vehicles(which is why my turn signal switch was worn out with only 8,000 miles on the car) Donor vehicles was the term I believe. If you really want a copy of the Assembly Manual for 1991 I can make a copy for you. I also have a parts list from West Coast from 1990 which gives all their part no's but nothing that will link them to any source(except Vern). For instance the rear end is part no C1-0010. My car was built by Dan Fiffick of A/C Specialties in Cleveland for a local client.
Hope this helps.
Jim Milliken
