o.f.m.,
Fella, I've used a lot of Lokars in my business building street rods and Cobras, but you've got me with the 'wheel'? Masnaka is right too, I have seen many, many guys have to use two hands on the brake lever to get it tight enough......but.....if it is adjusted right, one hand should do!
What ever it takes on your car for adjustment, just get the cable(s) tighter.
DV
PS-you can check the adjusters/star wheels inside the drums (Bottom of the internal backing plate)-but I would assume if these are too loose then your brake would be weak in either or both directions.
