Old 03-28-2009, 12:41 PM
patrickt patrickt is offline
Originally Posted by convincor View Post
My toploader doesn't have a drain plug. Is there room to drill/tap the boss in the case with the trans assembled.
Would removing the lower tail shaft bolt work as a drain?
Jeez, that's a lot of work. I would just suck it out via the fill hole. Look, here's how I do a real fast oil change before I put the ERA away for the winter. That's how I would do your transmission oil as well if it doesn't have a drain plug. I sure wouldn't yank it and drill it (wouldn't pull anything else out of it either).
