Old 03-29-2009, 08:56 AM
Tom Kirkham Tom Kirkham is offline
CC Member / Sponsor
Originally Posted by undy View Post
Ensure your puller fan is fully shrouded.
Ensure the inlet of your radiator is fully shrouded, all the way to the "mouth" at the front of the car. You WILL recirc hot air from the cooling fan's outlet if you don't at idle in traffic.
Ensure your timing and fuel mixtures are correct. Lean conditions and incorrect timing can aggravate coolant temps.
Dave
What Dave said is spot on. It is important to make sure ALL of the air flow goes through the rad.
Most engine builders set the timing on the engine very lazy. They do this to prevent the engine from detonating. You need to set your timing to come in quick and aggressive, yet still not detonate. With the timing retarded your engine will run hot and sluggish. This is a balancing act and you will need to drive the car and tune it.
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
