Originally posted by Jack21
... and it's about half the weight of an FE motor. Better for cornering and braking.
I don't agree with this statement. What is the weight of an all-there 351W. An FE with AL heads and intake is right at 500 lbs.
Originally posted by Sonny
... They are also lighter than 351C's and the stock 427FE engines along with being very inexpensive to build and maintain.
and while this might technically be true of a 'stock' 427, given the rampant use of aluminum by most in this forum, I think the 427 comes up lightest. It's not known as a 'thin-wall' casting for nothing.
I definitely agree that the Windsor is the way to go for inexpensive build and build-up. 427's are at the top of the scale with regards to cost/horsepower nowadays and if you're seriously racing, you'll be breaking/using up parts that'll need fixing or replacing.
JMO
