Thread: Edelbrock heads
Old 03-30-2009, 11:37 AM
Default Shelby are bigger
jimmymac Shelbys are bigger with 2.25" intake valve and 1.75" exhaust. There is room to port them. If you are runnig a Novi 2000, just gasket match the intake to the heads and open up the exhaust a little. Smooth the short radius out. You want a port demension about 82-85% of the valve seat opening. This will get you into the ball park. With boost you don't need alot of port work. Are you sure you can fit the blower under the hood without either a paxton hood or cutting out a fender? ASP sells any type of pulley setup you could want. I took mine off after 2 years of belt problems. I ran a double idler setup and still ripped belts( cloggs ). Oil return I tapped into the timing cover and had a Tee that was for the blower lube. I installed a filter to keep out any metal. I blow off valve is good, 2 are better. Is this FI fuel system or carb? If carb the air bonnet will hit the hood if you run a BT or Dove single plane manifold. Rick L. Have a large fuel system also. 1/2" line in and 3/8" line return. I run 2 pumps for steady pressure. Gessford has Blower brackets for this setup, Shelby may too. Rick L. Ps I made my own.
