Old 03-31-2009, 06:51 AM
mikey mikey is offline
I dont have it coupled up at present so I dont know. I do know that in the EFI status table the IAC is showing at 100% on ignition ie start up. I noticed that you can alter the amount of opening in the IAC opening versus ECT table is programmed for 100% - I am guessing that the Target Idle speed does not over rule this table and that I need to reduce the opening in the IAC vs ECT - am I assuming right?
I am using an MSD 6AL, but I followed the wiring instructions from ACCEL so I am now unsure why the timing was that far out as the installation instructions on the dual sync are pretty simple really.
Thanks for your help
Regards
Mike
Mikey B
